NM received an error code from the socket stub while trying to create the socket. The OSPF stack fails to start.
Check the network connection is correctly configured and working. If this does not resolve the problem, contact support with details of the problem.
Error
%p1% The socket creation failed. IP address = %p2% IP port = %p3% Error code = %p4%
| Name | Type |
| p1 | String |
| p2 | VarFmtByteArray |
| p3 | uInt16 |
| p4 | sInt32 |
